fuel sensor
Old Dec 2, 2008 | 09:37 PM
HARDTIMES's Avatar
fuel sensor
looking at a 97 for sale the ad says fuel sensor inoperative truck has 150,000 what do you guys think he is talking about?????.....thanks
Old Dec 3, 2008 | 07:57 AM
Racer9's Avatar
Probably "water in fuel" sensor, located at the bottom of the fuel filter. Sometimes the wires get wet and cause a false reading.
Old Dec 3, 2008 | 11:09 AM
infidel's Avatar
Or it could be the fuel level sensor, very common problem.
Old Dec 3, 2008 | 06:33 PM
HARDTIMES's Avatar
like as in fuel tank level gauge??? hard to fix???
Old Dec 3, 2008 | 06:56 PM
infidel's Avatar
Usually the problem is just the sender, about $60 from the dealer.
Dealer parts guy may say you have to buy the entire $300 tank module, not true.
Replacement wouldn't be hard except in order to access the top of the fuel tank you have to either drop the tank or tilt up the bed.
I prefer tilting the bed.
Old Dec 3, 2008 | 07:27 PM
Gene Kautz's Avatar
I was able`to repair the fuel sending unit in the tank there is a little arm that
makes contact with the sending unit.This is an easy fix took me about 2hr.
Old Dec 4, 2008 | 12:02 AM
wcbcruzer's Avatar
I think most people with these trucks have a fuel level gauge that doesn't work right. No biggie...
Old Jan 4, 2009 | 08:51 PM
wyododge's Avatar
Could you elaborate on your repair, I have the same problem.
Thanks!!!!
Old Jan 5, 2009 | 10:52 AM
infidel's Avatar
Thanks!!!!
Here are a few fixes.
http://dodgeram.org/tech/repair/fuel_sender/sender.htm
http://dodgeram.org/tech/repair/fuel...y_C-sender.htm
http://dodgeram.org/tech/repair/fuel...uel_sender.htm
Personally the labor of getting at the tank makes me feel like a new sender is a good idea. The new senders are improved and don't fail as often.
supr
18
May 21, 2007 09:29 AM
Gene007
0
Feb 26, 2006 04:31 PM
tyssniffen
Feb 11, 2006 01:28 PM
Booost Almighty
Jan 1, 2006 01:41 PM
wildmann
Aug 14, 2005 07:15 PM
