fuel pressure problem!! (I think?)
I was driving home last night and noticed the truck has less power? looked at the fuel guage and saw that i am running 18 psi at 1900 rpm and if i get into it the pressure drops to 10 psi! I am a little worried i really dont want to install a new IP pump right now! any one have a clue on where to start? i just replaced the fuel filter less then 2k ago and installed a 3k gsk spring and a #10 fuel plate less then 1000k miles ago? the truck has 178,0000 on it? do you think it could be a lift pump?
thanks for the help!
Your IP is fine though.............
Lets see if this works...........
If you pinch your return line and the fuel pressure goes up to 50 + lbs the lift pump is good. If so then I would replace your overflow valve. If it still does not go up then I would replace your fuel filter again, you may have gotten a bad tank of furel. I had this happen to me once and my filter pluged within 1/2 hour of filling up the fuel tank. It took 3 changes of filters before my filter change intervals started getting back to normal.
WOW!!!!
Thanks for the help guys!!!
I pinched the line and the pressure shot up to 60 psi! so my lift pump is good right? so now i need to fine a overflow valve! does anyone have and ideas on what and where i should get it? I have a 3k spring and a #10 plate on my truck!
Lift pump is good, get your overflow valve from larry b, they say he is selling the torqtec adjustable one now.
http://www.larrybs.com/
http://www.torkteknology.com/product...OVERFLOW-VALVE -OFV010.html
Ofv
ok! so i got the new OFV and installed it last night started the truck up and the pressure shot up to 28-30 psi at idle so i reved it up and at 2500 rpm no load the fuel pressure went up to 35-36 psi so i took it for a ride and it runs great but when i geat into it the fuel pressure drops to 27-28 psi around 2500 rpm with a load is this normal? i dont remember that from before! I have looked but have had no luck finding a fuel leak! it feels like the truck is not as strong as it was before my problem started!
Thanks for the help!
Make sense? lol
5.9Excursion
55
Feb 26, 2020 09:55 PM
HOHN
Jun 29, 2008 08:35 AM
callum
Nov 21, 2004 07:04 PM
