fuel pickup at tank
Old Apr 12, 2009 | 11:02 PM
vsimkus's Avatar
fuel pickup at tank
Hello
I'm in the process of replacing all of the fuel lines between the engine and the tank. I noticed that the steel lines coming out of the tank at the pickup are getting questionable and I'd like to replace them as long as I have everything apart.
Are those lines in the tank pickup replaceable? I realize that some rigging will be required, but NAPA wants close $400 for the whole unit - with the float etc.
Anyone have any suggestions?
Thanks
Vic
Old Apr 13, 2009 | 09:23 AM
kawi600's Avatar
You can pry the plug out of the sender (the one that has the pickup in it). The vulcan draw straw fits in there, but to retain the float and one-way valves in the sender assembly, youll need to replace the nylon tube coil with something else and clamp it in place.
I tried a few bits of nylon tubing I had here, but I didnt have one of the right thickness so it was too rigid to use in there. I used a piece of diesel fuel hose instead.
Dont run a straight pickup down to the bottom of the tank, the sloshing makes the last 1/4 tank unusable
Old Apr 13, 2009 | 09:49 AM
infidel's Avatar
Either the Vulcan Draw Straw or you can get a rebuilt module from the dealer with the improved sender for $125. The rebuilts have plastic instead of metal lines that won't rust out.
Hope you're replacing the lines with hose all the way, not the stock metal lines.
Marine grade hose will easily outlast your truck.
Old Apr 13, 2009 | 01:07 PM
vsimkus's Avatar
Thanks for the info, guys. No stock metal lines here
The draw straw seems reasonable. I think I'll go with that. To clarify, I should specify the 'flexible nylon' draw tube when ordering?
Thanks
Vic
bgilbert
Jun 30, 2006 11:48 PM
neverhme
Jun 19, 2006 04:53 PM
RAF
13
Mar 4, 2006 03:18 PM
RowJ
19
Jun 14, 2005 12:23 AM
