Fuel leak - fixed
Fuel leak - fixed, questions still.
Over the weekend I put about a thousand miles on my truck hauling a couple of cars for a friend. About a half hour from home I started smelling fuel when just the driver window was down. I stopped to fill-up about 10 miles from the house and noticed a fairly substantial leak from the fuel filter area. I put a few gallons in and limped home.
I could see the area it was leaking from but not what exactly was leaking - either the fuel filter or the drain valve. I replaced just the filter using the original drain valve and problem solved. The old o-rings didn't look bad and I can't see any real reason for the sudden leak.
Is this a common problem? I want to be prepared if it is. I just got the truck a few months ago and don't know how old the fuel filter was - didn't look too old.
I also cleaned the engine bay at the carwash and now my WIF light is on(runs fine). I may have gotten the connection wet, is there a way to reset that light?
Thanks,
Ryan
Thanks,
Ryan
Filter was tight, o-ring looks to be in good shape, and the valve was tight. Does the drain valve ever just get "hung up"? Either way my problem is fixed...... and I probably needed a new filter anyway.
I'll hit the sensor with some WD and see if that does it.
Thanks.
Thanks.
CTD Hauler
Feb 17, 2009 07:51 AM
jwtuc
14
Mar 22, 2004 08:35 PM
