Fuel leak
Fuel leak
I was going to say persistent, but I really haven't had for that long. I'm new to the diesel world with recently buying a 89' D250 Farm truck with a 727. I had a fuel drip coming from the bottom of the water in fuel sensor. I cycled the drain a couple times and it looked like it stopped. Wrong, then I replaced the filter with one without the sensor and again I thought the leak had stopped. Today's update: Didn't drive it yesterday. Went to town and back (50 miles) and found the filter wet again. Not dripping, but wet. Any ideas where I should look next? Apparently the filter housing is the source of the current leak. Is there anything specific that is the usual problem?
Thanks,
Thanks,
Thanks,
Cummins Guru
I would check the threaded fitting that the filter screws on to. If this lose it will allow the fuel heater to leak which is just above the fuel filter.
To answer your question, I don't know why it's needed, all I know is my fuel filter will leak if I don't put the oring on.
On my truck, the fuel filter comes with a smaller oring that slips over the nipple that the filter screws on to, and if I replace the filter with out that oring it leaks every time. I've also been in a hurry and forgot to take the old one off and double gasketed it and that makes it leak as well.
Maybe that's the problem, I'll check in the morning.
Thanks,
ZPOD
18
Sep 23, 2010 10:37 AM
superdiesel9
Oct 25, 2009 07:56 PM
donhov
26
Jan 6, 2006 07:29 PM
Lightman
16
Jan 21, 2004 10:46 PM
