Fuel basics
Old Mar 22, 2008 | 10:29 PM
harpazorick's Avatar
Fuel basics
I am just getting interested in my 12 valve. If some one would be kind enough to answer some ? for me. I would appreciate it.
1. which fuel plate gives the most fuel? a 0 or a 10. and are their 11 fuel plates?
2. what plate is on a stock truck?
3.How mutch fuel can you get from the star weel?
4. Delivery valves how mutch can you up size your injecters before you want to get begger valves? or is it based on the sise of the fuel plate?
Now for a techical question.
5. How mutch hp is gained per degree of boost air cooling?
Old Mar 22, 2008 | 11:25 PM
bentheir_05's Avatar
1. the 0 plate is much more aggresive fuel than the 10 plate and yes they do make 11 plates check out www.tstperformance.com
2. well first you need to figure your year and auto or manual? then you can find out what hp rating you are at stock then (assuming it hasnt been tampered with) you look at the site mentioned above then depending on your trans go from there. tst has a good HP/TRQ chart for their plates
3. the star wheel actually only increases the low boost <5psi fuel but however you can slide your stock plate forward and gain 15-20 hp respectfully just do a search on fuel plate sliding or something along that line.
as for the questions about #4 and #5 hopefully some with a little more advice will chime in and help you out.
EricE
Sep 28, 2006 04:36 AM
8mpg
Apr 17, 2006 01:44 PM
APD
Mar 10, 2005 11:24 PM
Ian
Mar 5, 2005 08:20 PM
TurboPirate24v
Mar 2, 2005 05:26 PM
