Front differential bad ?
Old Jan 30, 2019 | 12:23 PM
Lee Kelley's Avatar
Ok got my truck stuck in a deep snow drift hauling firewood. 4x4 was working. Had to have truck pulled out the next day. Got In the truck started it up and let out the clutch and heard a loud pop, assumed it was the tires breaking free from the ground. Took forever to get the truck out was buried bad. Anyways once it was out and should have been able to go on it's own I realized the 4 wheel drive wasn't working. 4x4 light is on. Has new actuator and lines have no leaks. I have looked under the truck and driveshaft is turning. Rear tires just spinning on ice and truck not moving but front shaft does spin. So I don't believe it's the transfer case. Have pulled actuator off the axle was locked in. No noise coming from front differential when truck is moving. So not sure if I have broke something in their or not.
Old Jan 31, 2019 | 11:15 AM
patdaly's Avatar
Time to get it inside somewhere and pull the front diff cover. Almost sounds like a broken axle shaft.
redpoint5
26
Apr 5, 2010 01:11 PM
jiggerman78
May 2, 2009 06:38 AM
65fury
25
Apr 6, 2007 08:16 AM
Buckshotram
Jan 9, 2006 09:27 AM
C Pierce
Mar 21, 2005 08:41 AM
