foaming at #1 injector
Old Jan 4, 2006 | 12:24 PM
plow's Avatar
I have a slight miss that can hardly be heard have't to lisren close to hear it.So I cracked some injector lines to check for air all is good except for #1 it wouls just foam and spit, no spray. Also engine pitch changed every time I cracked a line except when I cracked #1, BAD INJECTOR please confirm. Thanks
Old Jan 4, 2006 | 12:34 PM
TIMMY22's Avatar
take it out and have it "pop" tested.
usually, if you have a skip and you crack each one individually (like you did) it will point you to the trouble. if the "pop" test comes back good, you know it's either fuel delivery (pump/line) or a mechanical problem like valves etc.
start with fuel delivery.
good luck
Old Jan 4, 2006 | 12:39 PM
plow's Avatar
Can they pop test at a dealership or should I take it somewhere else. By the way haw much does a pop test cost?
Old Jan 4, 2006 | 12:46 PM
TIMMY22's Avatar
most diesel shops should have a test stand. you would have to look up the specs on your injectors. a buddy of mine has a diesel shop and he would let me test 'em for the bubble.
depends, probably like $40 for one maybe $100 for all 6.
if you buy the new injector from them, maybe free?
Old Jan 4, 2006 | 07:20 PM
infidel's Avatar
As long as they don't have to remove it my local John Deere dealer pop tests for $5 per injector. They can also rebuild them most times for less than $100.
Old Jan 4, 2006 | 09:03 PM
Stamey's Avatar
Maybe time for a set of Mach 2's?
Chris
zog
Dec 28, 2005 07:06 AM
kennedy
Aug 3, 2005 09:23 AM
hfd376
Jun 21, 2004 07:45 PM
Lowco
Mar 9, 2004 08:17 PM
Suburbanite
Nov 9, 2003 01:05 AM
