First fuel leak on my
Spotted a steady fuel drip just above the front drive line cardon joint- on my 1995 (not sure why subject is not editable) working 10 hour days 6 days a week, zero time to put in new lines- or even change the oil in my commuter car for that matter- these are stock fuel lines, is there a connector or known troublesome leak source that I can quickly spot and fix? Thanks guys, Joe
If you're talking about the where the front drive shaft enters the front axle, well the fuel lift pump is right there above it bolted to the side of block. Accessible through the front wheel well....but almost the entire fuel system is also there, up higher and a bit forward. fuel filter, heater, filter drain line, return line, injector pump, etc. Its all on that side of the engine. Only thing on the other side is injectors.
So I would first look at the lift pump, then the filter/heater/drain. You're just going to have to look, a steady drip should be easy to track down.
Morsel
02-05-2018 05:50 PM
ZPOD
18
09-23-2010 10:37 AM
donhov
26
01-06-2006 07:29 PM
