Fan will not come off
Hi Guys
I'm here at my shop , this fan will not come off , I have tryed the punch , I have a 36mm wrench , I have even used a air hammer ... I don't want mutalate it any more ... Any more tricks ...? Greg [duhhh] |
threads are backwards on the fan.
RE: fAN
I have been hitting towards the drivers side ...down ward .
More help ...Please . Greg |
I hate to admit this but my fan came off with a pair of pump pliers. If yours is that stuck you may want to try some heat and/or penetrating oil. It sounds like the last person didn't use anti-sieze.
Holy crap ...
I had to take the bolts off the pully and it gave me enough room to get the mount with the fan ...all in one unit .
Now its out ... thats a work out , I will and try and use some penatrating oil on it over night . Thanks guys . Greg |
I took out 3 of the pulley bolts and used a big adjustable wrench and I cut a "C" shape into a cheap air hammer bit to help it engage with the big adjustable - worked like a charm.
Remember it is a LEFT hand thread...pretend like you are tightening it. Mine was stubborn too...but I did the punch trick, and then the wrench...spun right off.
I did mine with the belt on...need smoething to hold the fan from spinning. |
Re:
I got the whole block off , I have the thing soaking over night , some how I'm going to have to lock the pully in place and try and wench this thing off .
If I use heat I would say I'm buying a new clutch ... the fan looks a little beat up ...like it ate a cat or two ...LOL I might have to buy a clutch ... I hope not ... my limited buget is getting smaller , I have to get a new belt , upper and lower rad hose's ... so far ... if I'm in there I'm doing them now , the there all original . Later guys Greg |
I take my fan off every fall and re-install in spring. Some years I can barely get it loose with a wrench set on the hub nut and pulley. Some years it comes off with water pump pliers. I use anti-seize, too.
There is a kit available that is a 36mm wrench (among other sizes) that hooks up to a swivel and plugs directly into your air chisel, for removing stubborn fan clutches with no damage. It is the greatest thing ever!! [guitar]
Back on the job today
the fan will not come off the block , I even have the snapon fan removing tool , I actually bent one of the little pully heads .
I tried light heat more towards the clutch it self ...I don't want to hurt the block bearing . Looks like my only choice is to cut the clutck after the nut and try a big socket with impact gun [duhhh] Any one with any other ideas Greg |
Fan help again ...
I cut the fan off the bearing block ... The threads are no longer there ...
Looks like I need a new bearing block or a new shaft that press's into the block ... any one ever have this problem ...sucks to me me . Greg [duhhh] |
Never heard of this before, but doesn't mean it hasn't been a small problem.
Contact your local diesel performance shop. They may have one from a parted out engine. |
Re: fan
This is where I'm at , The bearing feels like it has some issuse's , it kind-a feels like a knob on a safe ... little clicks when you turn it ...it's bad .
I from what I can tell I just got the timing cover off ... very clean inside , Has any one ever seen this , some drilled a hole in the timing cover housing in the perfect spot to insert a taped bolt right in front of the pin . I am going to still put the tab on and button the cover up . Dose any one know if I will have to go to dodge for this bearing and block and dose it come as a complete unit ...? Thanks guys Greg |
You can get a engine parts breakdown for your engine by registering here
https://qsol2.cummins.com/info/matrix.html You will need your engine serial number from the plate on the timing gear case. Buy the parts from Cummins, not the dealer |
