Engine Speed Sensor
Old Nov 14, 2009 | 01:58 PM
manureman's Avatar
Engine Speed Sensor
Thought I had one out, so I put a new one in. I didn't know about the trick of using the credit card or non-magnetic feeler gage to set the gap. I used a regular old feeler gage to do it. Still no tach, A/C, Cruise. Could using a regular feeler gage cause this? It was a little hard to get it out, because of the magnetic pull, but I did re-check the gap with a credit card after I found out my mistake and it seems ok. Did I just ruin the new ESS?
Old Nov 14, 2009 | 04:10 PM
RPegram's Avatar
Check the wiring from the sensor to pcm. I have heard of wires breaking and causing similar problems.
Old Nov 14, 2009 | 04:46 PM
torquefan's Avatar
Don't worry about the steel feeler gauge. I've set dozens of them with a steel gauge with no trouble. The problem with the steel is that the sensor's magnetism affects the feel of the gauge as you slide it in and out to measure clearance.
sjester
May 10, 2007 05:03 PM
kev211
Feb 13, 2007 07:02 AM
wildmann
Aug 14, 2005 07:15 PM
CZSteve
May 16, 2005 11:51 PM
sethrector
Apr 13, 2005 06:44 PM
