EGT too high?
Old 05-25-2013, 08:24 PM
mtdoragary's Avatar
EGT too high?
I ground my plate to #100 specs, and reduced the boost signal and now instead of occasionally seeing 900 degrees under very hard pulls, I can tap the throttle and see 1150 in a heartbeat. The plate seemed awfully far forward (almost all the way) when I opened the top. I put it back to the same position after grinding the plate. I'm thinking that when my governor spring kit gets here, maybe I should move the plate back a bit.... maybe center it. What say you?
I have stock exhaust and air filter.
mtdoragary is offline
Old 05-26-2013, 11:41 AM
How soon do you want to put in new pistons and rebuild the engine?
Robert Rausch is offline
Old 05-26-2013, 12:25 PM
somis13's Avatar
I run mine at 1200 everyday for minutes at a time and have been doing it for years. keep it under 1250 if your pyrometer is pre turbo and if its post turbo keep it under 850. my 10 plate is full forward, i believe the 100 plate has no defueling at high rpms tho. good luck
somis13 is offline
Old 05-27-2013, 08:33 AM
CarlJensen's Avatar
You can run 1200 all day. You have more fuel going in and if you want the temps to come down you need more air. It is a balancing act between fuel and air.
CarlJensen is offline
Old 05-29-2013, 08:11 PM
mtdoragary's Avatar
My governor spring kit arrived today. I'll slide the plate back a bit when I install the springs. Gotta do something about the stock exhaust too.
Old 05-30-2013, 11:25 AM
If you still have the cat it could be making all the difference, most are clogged by 100k miles.
infidel is offline
Old 05-30-2013, 01:51 PM
mtdoragary's Avatar
The cat is still there. Don't know if it's gutted.
Old 05-30-2013, 08:31 PM
I kept my kitty in the corner of the shop for future emission laws
joem is offline
Old 05-30-2013, 08:40 PM
mtdoragary's Avatar
I'd LIKE to put a 4" exhaust in like I did on two of my other Cummins, but my funds are exhausted. So I'll gut my kitty.
Old 05-31-2013, 09:39 AM
Lil Dog's Avatar
When the cat died on mine, I gained 1-2 psi boost and lost ~150F EGT... My first move before the exhaust was the Cat Delete pipe as you have to go from the stock 3" up to 4" inlet to the muffler.
Lil Dog is offline
Old 05-31-2013, 04:04 PM
mtdoragary's Avatar
killing the kitty on the 96 took more time and effort than the complete 4" install on the 93 ! The catalyst didn't look plugged.
Old 05-31-2013, 11:46 PM
yeah, its a PITA- seen people use a 2" flat wood bit- that's why I just kept mine for whatever happens down the road. Did you notice a bit more exhaust tone?
joem is offline
Old 06-01-2013, 10:05 AM
mtdoragary's Avatar
I used a 1" by 18" wood bit and a 12" extension, and a piece of rebar and a piece of 1" round stock. haven't cranked it since the gutting.
Old 06-03-2013, 12:19 PM
mtdoragary's Avatar
Took out the nasty paper filter that came with it and put in a nice Wix. Dropped my EGT 150 degrees.
Old 06-05-2013, 11:29 AM
mtdoragary's Avatar
Installed GSK and #10 plate. Measurements on the governor springs BEFORE removal were .025 and .065. I set them both at .040 after install. Haven't cranked it yet because I was missing one banjo washer. Going to the store.
Haven't noticed any exhaust tone change since kitty was euthanized. Tranny shifts quite hard, so I suspect a kit in the tranny, but no TC upgrade. At some point a Goerend TC will be transplanted. Hopefully NOT during one of my trips moving everything from Florida to north Alabama with my 34' Wells Cargo gooseneck!
tinknocker827
13
12-04-2013 06:26 PM
dustyman440
07-10-2007 08:29 AM
bigwheels94
24
08-15-2006 09:57 PM
cheff
01-23-2006 09:44 AM
forcefed88
10-13-2004 11:36 PM
Quick Reply: EGT too high?
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
