EGT question for school project.
Hi all,
I am a student in engineering and as part of senior design project I need to know some information for my project model. Pretty much what it comes down to is I need to know the difference in temperature of exhaust gas before and after the turbo. Let's assume we are talking about cruising speed of 60 in overdrive in standard conditions (approximately 70 F), what ever that rpm may respond to. I know, it changes based on turbo and from truck to truck, but I just need a decent estimation to see if the project idea is worthwhile. So if some of you run gages pre-turbo, please let me know what kind of temperatures you are seeing. Same for post turbo. Also, do you guys happen to know if you would see similar temperatures in spark ignition engines?
The help is really appreciated. Thank you!
Yup, that definitely helps, that's the difference I was expecting to see. Now, I just have to figure out how much of that goes to potential work and how much is due to heat transfer. Thank you for the reply!
Yes, I understand that. The current goal is to see what is the potential to do work (ie find the exergy) at normal driving conditions. The next step would be performing similar analysis at various conditions. I will have to develop an algorithm that will take into account all these variables once I am certain that I can get what I need at cruising conditions. Thanks.
Foxborough
Feb 28, 2008 09:40 AM
00turbo
Oct 19, 2004 04:02 PM
BDude555
13
Mar 15, 2004 08:09 AM
