Early 2-3 shift point for a 97 with a lower stall converter?
Old Oct 6, 2006 | 12:20 AM
Jerret's Avatar
Hey everyone,
I'm planning on upgrading my TC and VB fairly soon, I've been told that doing so will result in my transmission shifting earlier then it does today with WOT and going from second to third. The rpm drop will be from ~2600 to ~2300.
Apparently, this has do to with the computer controlled shift points in the 97 47re transmissions. At 40 mph the computer will say hey, it's time to shift and force the shift point. Does anyone know of a work around?
Thanks!
Old Oct 9, 2006 | 03:04 PM
Jerret's Avatar
Does anyone have an upgraded converter and valve body on a '96 through '98? If so, how has your 2-3 shift point been effected?
Thanks!
Old Oct 9, 2006 | 03:29 PM
Mcmopar's Avatar
96 with an early shift condition under "very light" throttle, not a problem at WOT!
Old Oct 9, 2006 | 04:41 PM
Racer9's Avatar
I have the light throttle, early upshift problem on mine, with the Transgo kit. The instructions say to turn the TV screw in, but not how much. I tried 2/3 of a turn, wasn't enough. I'm planning on calling them to find out how much to turn it, when I'm not so busy.
Old Oct 9, 2006 | 05:15 PM
Jerret's Avatar
Mcmopar - do you have an upgraded valve body / converter?
Under WOT I was told that with the new (lower stall) converter and valve body my truck would shift earlier than stock @ around 2300 rpms.
Old Oct 9, 2006 | 07:10 PM
88bird's Avatar
i heard that that allen screw that is turned that 1 turn = 3psi
i have a Goerend tranny, converter ..... whole 9 yards... i have an early shift at light throttle and at 2300 or so at WOT.... i was told by Dave that he's working on getting a fooler so the comp dosen't see the high fluid pressure..... if it really bothers you just manually shift it..... that's what i do....
Old Oct 9, 2006 | 10:51 PM
Jerret's Avatar
Thanks 88bird, that confirmed what I was hearing as well. I spoke with Dave a couple days ago and he said the same thing, although he didn't mention the trick you referred to.
I was hoping there might be a PCM flash or something else along those lines that would resolve the problem.
Old Oct 10, 2006 | 07:35 AM
Mcmopar's Avatar
Yes,
It's a low stall single disc converter, with a valve body I built using Dave G components. I upgraded the internals to have more clutches, etc,etc.
Old Oct 10, 2006 | 10:47 AM
Jerret's Avatar
My guess is that you're not expirencing this because you have a 98.5 which (I'm guessing) has a different shift control mechanism.
Thanks everyone, it sounds like I’ll have to live with the “2-3 stacked shift” for the foreseeable future.
Old Oct 10, 2006 | 11:04 AM
Mcmopar's Avatar
Nope,
This was on the 1996.
flyingd
17
Jul 11, 2017 11:13 AM
bngcustoms
Jul 17, 2009 04:53 PM
CACalomino
20
Jun 26, 2007 07:19 PM
kully560
Mar 9, 2007 02:40 PM
JD730
Aug 2, 2005 11:33 AM
