Cyclic whining noise. Please help diagnose
Hello all, firstly I'd like to begin by saying thank you for your time and advice in advance if you are here.
Truck: 96' 2500 auto 4x4 5.9L odo-165k , mostly stock.(gov springs, KDP) Issue: Cyclic whining noise that presents itself above 15-20 mph. Idling or below 10mph not audible. Braking and accelerating do not effect the noise. Troubleshooting this far: - Checked wheel bearings for play, all wheels good, except passenger side Rear has the slightest play. (I hesitate to include this info because I really don't think this is a wheel bearing noise, though could be) - Engine fluids all normal and at appropriate level - P/S works - Noise seems to come from driver side, front of vehicle, not sure if engine bay but likely - Speed does effect the cycle of the whining, but not much at all I suspect it is a vacuum pump or vacuum line, or the 4x4 CAD vacuum fork shifter (yes I'm a noob and don't have posilock). My next troubleshoot is to get a vacuum gauge and test the pump and lines. I am attaching a few videos of the noise. Please forgive the wind noise (volume warning) as well as my poor camerawork. In case you guys didn't know its hard to drive safe and record :^) 1. 2. 3. I kindly ask for any advice. I am an novice mechanic at best so I could use some pointers for troubleshooting methods. Thank you |
It sounds "rotational", which if I had to guess, it would be driveshaft related, axle related, or brake pad related. Rotational squeakey's are usually U joints going bad.
Originally Posted by NJTman
(Post 3382822)
Originally Posted by Angrytrukker
(Post 3382828)
I did check for play in all U-joints, there was no U-joint play.
The suspension components could use a greasing, and I will get that done and see if sound persists, but I don't think that's the cause. Not to doubt you.. but I will try it. Thanks
(Post 3382830)
(Post 3382828)
I had a U joint fail (china made) in my front axle. Tight as could be. No play whatsoever. Two caps were rusted to the trunion solid, and when I went to turn they squealed like a democrat screaming racism. Brake pad sensors can cause this too. get the truck onto 4 jackstands, off the ground.. Get someone in the truck to slowly get the wheels spinning. You'll find the "squeal source" relatively fast. |
Check the boots on your inter-cooler.
Not rotational but they could be loose or cracked and blowing. Just trying to think of things on the driver side that would/could make noise. P |
(Post 3382846)
Joint play is irrelevant. It's as Fordzilla stated, greased or not.
Originally Posted by Sleigher
(Post 3382852)
