Clogged Crankcase breather?
Ok guys so I recently acquired a 94, the one in my sig. It seems to be building pressure in the crankcase, and then puking oil out the dip stick tube. What do you think could be causing this? I’m thinking maybe the breather is clogged and not venting properly? Any input would be greatly appreciated thanks!
Look at the hose between the brake booster and the vacuum pump for a "T". Unplug the smaller line and plug the T with a small hose and a nail or something. Then drive it and see if it gets better. The cruise control or A/C controls could be leaking. The booster could be bad but you would complain about bad brakes. It could also be a bad seal in the vacuum pump.
The vacuum pump discharges in the crankcase.
You can see the crankcase vent tube by the starter. Most crud will be near the end of it where you can see it. You can also look at it while its running to inspect blowby after you prove the vacuum system is correct.
Thanks dguru! I did exactly what you said and plugged off the vacuum port for the curse control, heater etc. and the crankcase pressure and dip stick oil puking are gone. Any ideas on where the leak might be/ tips on common problem areas? Or am I pretty much on my own just to find a cracked line etc.?
Most common leak areas are:
An acid corroded line under the driver's side battery to the cruise actuator.
Turbo heat melted line though the firewall.
Disconnected lines in the fuel filter area.
Disconnected lines to the t-case and front axle.
Jmac
09-03-2010 07:31 PM
4x4BOB
16
02-05-2010 06:29 PM
BigBRUNO4
09-09-2006 06:30 PM
silverram323
08-15-2003 06:21 PM
