Cleaning TPS
Old 05-24-2017, 02:37 PM
Robert Rausch's Avatar
Cleaning TPS
Has anyone here cleaned their Throttle Position Sensor? If so, how did you go about it?
Old 05-24-2017, 08:12 PM
Admin Team Leader
Lary Ellis (Top)'s Avatar
Waste of time in my opinion...if you saw the inside of one you would see that if it helped at all it would likely be temporary. Replace it and be happy you are done messing with it
Old 05-25-2017, 12:24 AM
Ok. Thanks Lary.
Old 05-25-2017, 12:54 AM
Anybody got a link to a good place to buy one?
Old 05-25-2017, 01:08 AM
What about getting a TPS delete kit? I see them on ebay. Anybody here run one?
Old 05-25-2017, 08:30 AM
berner's Avatar
I had issues with the connector on my TPS. I sprayed it with contact cleaner, blew it out with air, and carefully tightened up the barrels with a small screwdriver. It's been good for a couple of years.
Old 05-25-2017, 09:20 AM
patdaly's Avatar
Don't forget to make sure your bushings are good on the TPS linkage..... with the miles you have they are probably shot, that can cause the same issue.......
halfpint23 (06-01-2017)
Old 05-25-2017, 12:02 PM
Thanks Pat. I Just checked mine. There is a slight amount of play in the TPS bracket/shaft but not nearly as much as in the video. Never the less it's something I should probably do. Do you know where I can get the parts? Cummins? Larry B?
Old 05-26-2017, 08:15 AM
patdaly's Avatar
MaMopar, looks like about 7 bucks each, PN 04425053.
Old 05-26-2017, 11:03 AM
Thanks again Pat!
Old 05-26-2017, 09:28 PM
I ordered a TPS delete kit, but I'm going to also get new bushings for the shaft and install them.
Old 06-02-2017, 12:04 AM
Required_Field's Avatar
To your original question, years ago when I first got the truck, it was exhibiting the hunting and in-and-out of OD problem. I cleaned the TPS with electrical parts cleaner spray, and it solved those problems for quite awhile. After I resurrected the truck last Fall, in the colder weather, it displayed those problems again, until the engine & trans warmed up. I was going to clean it again this Spring, but haven't gotten around to it yet. Good to know there are other options like the delete kit and bushing replacement.
whosdunit
05-17-2014 08:54 AM
SHARPMACHINE
15
08-01-2007 07:28 AM
TIMMY22
07-13-2007 09:27 PM
snow ram
05-17-2006 06:37 PM
GSP
08-01-2005 08:29 AM
Quick Reply: Cleaning TPS
