Cat on a 96?
Old Mar 31, 2010 | 12:52 PM
SmokeN 12 ValvE's Avatar
Cat on a 96?
Did the 96 2500's and 3500's come from the factory with a cat?
I found one place that said they did, but can not find one anywhere. The DMV said I have to have all the emission crap on there when it gets inspected to be switched to a diesel.
Old Mar 31, 2010 | 01:34 PM
Lary Ellis (Top)'s Avatar
Admin Team Leader
My 96 did indeed have a Cat on it from the factory.
Old Mar 31, 2010 | 03:28 PM
Thanks for the reply.
I don't want to take any chance of it not being right, it only has to get checked one time for them to change the registration, then the straight pipe goes back on. The other diesel's I have owned when it came time for the normal yearly inspection, they just change the sticker, never checked anything and I'm own my way.
Old Mar 31, 2010 | 03:49 PM
One more quick question, What's the diameter of the pipe?
Old Mar 31, 2010 | 06:55 PM
infidel's Avatar
You might want to post an ad for a used cat, a new one went for $900 when I checked a few years ago.
Maybe someone could even loan you one.
Old Apr 1, 2010 | 12:11 PM
waldersha's Avatar
3" inlet, 4" outlet I believe. Then 4" into the muffler 3" back out. I'd let you borrow mine, but it's a drive from NC to here.
Old Apr 1, 2010 | 12:19 PM
justme-'s Avatar
I am not sure if all 96's came with cats- as it had been reported some has resonators in line with the mufflers. I know in emission states like MA and CA they did have cats tho most inspection stations have no idea (and wouldn't believe me if I said it was a cat "no, diesel's don't have cats") so would have no idea if something was missing.
MA changed their diesel inspection rules recently requiring emissions inspection of most diesels (used to be emission exempt) but 1996 specifically are exempt. Pre OBD2 are tested one way (up to 95), post OBD are tested onboard, 1996 is singled out as exempt as there are only a handful of 1996 diesel's on the road in the state (official explanation!!)
Old Apr 1, 2010 | 07:47 PM
jtamulonis's Avatar
the only dodge trucks that I`ve seen with cats were california certified. there may be others though. check the cpl tag on the timing gear housing. it will tell you if YOUR engine had a cat, egr , or any other smog devices. I think `96 cummins only used cats and egr for smog. the cpl tag is the final word for your engine. it will tell the smog jockey what smog devices came on your truck.
Old Apr 1, 2010 | 08:08 PM
infidel's Avatar
Starting Jan 1, 1994 all 12 valves sold in the US came with a cat.
The only 12 valves without a cat were early '94s.
Engine evolution> http://dodgeram.org/tech/dsl/Facts/epa_changes.htm
NVMike
Mar 7, 2007 08:24 AM
1969mach1
Mar 4, 2007 06:39 PM
Doubleover
Apr 30, 2006 03:02 PM
Rare1
Jul 17, 2004 08:48 AM
