Can I burn used engine oil?
#61
Been burning used oil in my trucks for 30 years. Heavy in the old detroits, a gallon to a tank in the dodges, one 12 valve one 24 valve. Run it when I have it in the cummins red top n14. Engines run quieter and smoother and better mileage with wo.
#62
just an FYI
The cummins system was called Centinel.
Basically automatically took oil from the crankcase end of the unit, and pushed it back to the fuel tanks. Engine oil was replenished from an OEM supplied make-up oil tank mounted on board.
Worked fairly well, however, with the attention span of most operators these days, I don't see the make up tank getting checked often enough, would probably lead to problems down the road.
#63
Used engine lubricating oil can be blended with fuel using the Cummins Lube Oil Blender, Part Number
3376317 (110 volt, 60 Hz) or Part Number 3376362 (220 volt, 50 Hz). This process can be used to
supplement fuel supply as well as provide a means of disposing of used lubricating oil.
To blend used engine oil with fuel, follow the instructions provided with the Cummins Lube Oil Blender.
You got one of those? Or do you just dump your contaminate filled oil directly into the tank. Let me know how great that engine is running when it gets to a half million miles.
#64
When the switchover to ULSD happened it also became illegal to add used oil to diesel in all 50 states.
Highly doubt anyone is checking though...
#65
As of a year ago the centinel was still available, not for the b series 5.9
https://quickserve.cummins.com/info/.../centinel.html
I would like to know what a "small amount" is. I'm betting it isn't the 30:1 mix that has been suggested by some posters. I see no wisdom in taking the contaminates out of the bottom of the engine, then feeding them into the top. I ran across a list from Cummins of all the bad stuff in used oil (the reason we change our oil) earlier today, but can't find it now. The list included dirt and sulphuric acid, among other things. So go ahead guys, dump that crap into your fuel as much as you want, and convince yourselves that you are getting better mileage, saving money, etc., etc. I'll just keep chugging towards 700k miles.
#66
#68
so i can see where this will work but do ya'll just dump it into the tank and hope that it mixes or do you take the fuel home and mix it or what? and can i get a definitive answer on putting used synthetic oil into the tank.
#69
burning 65%+ motor oil/ATF right now...
no real difference in startup or running.... except cummins runs smoother with better fuel mileage.
I get a puff of smoke during startup, then can't see anymore smoke.
does exact same with 100% diesel.
idle was adjusted upwards a bit for 65% oil mixture. but my idle was a bit low to begin with.
starting to think the best way is to source your waste oil from a source that keeps it clean. ATF flush typically uses 5 gallons. avoid waste motor oils from a repair shop as they will mix oils contaminated with antifreeze from blown head gasket jobs.
#70
#71
I see a guy running around here in a 12v that burns oil. 3 gallons per tank (27 gal diesel) and his truck smokes so much. Its annoying when he drives by because it hazes at idle and smokes like crazy when he hits the pedal. Hes been doing it for 40k miles though and hasnt had any problems.
#72
no way I'd knowingly run synthetic. however... if one is running waste oil. there's no way to know if synthetic got mixed in...
I'm running 50%+ with no smoke, except a puff at startup. which is exact same running 100% diesel.
#74
#75
Nobody has mention this www.myfastfuel.com/index.html .They claim they use a polymer filter like The US Army has used for ages to remove the contaminants and mix varying amounts of diesel in then pump it in to the vehicle tank .Anybody have any experience with it?
