Brake Leak?
Anyone had a break leak?
Im in the middle of trying to trace a new leak. Havent narrowed it yet, but the only thing i can see it moisture on the hardlines coming out of the brake assembly. Im getting a small amount of fluid on the shock tower and running down the fender well. The brake system is the only thing that far towards the driver side i can find. I have also had 3 times where the brake lights all go on, and dont operate properly. all at low rpm, low speed. ANy ideas, tommorow ill degrease the whole underhood and sit and wait for a leak i suppose |
Hydro booster?
If you have a hydro booster I'd check it out. also check the power steering fluid level.
If you have a vacuume booster check that. SFB |
