black goo in turbo????
Old Mar 12, 2010 | 07:10 PM
faylorz's Avatar
A buddy of mine took apart his he351ve to inspect it and we found a rubber goo like substance almost like rubberized undercoating all over the inside of the compressor housing and the compressor wheel. what is it? any ideas???
Old Mar 12, 2010 | 07:17 PM
Astro's Avatar
Is he running a K&N or oiled air filter?
grail4life's Avatar
any shaft play??
Old Mar 12, 2010 | 07:19 PM
faylorz's Avatar
no he is running a bhaf but he bought the turbo used so its possible that a k&n was on it. it was on there pretty thick and on everything. so a k&n is a possibility for the problem?
Old Mar 13, 2010 | 12:55 AM
Astro's Avatar
EDIT: I just read that it's an HE351VE. I was thinking HX35... Either way, could be dirty filter, or sucking oil from bearing housing.
Old Mar 13, 2010 | 07:51 AM
trainermg's Avatar
I am around a lot of big truck engines all the time when the turbo inside is dirty they claim the fuel your running .
Old Mar 13, 2010 | 10:19 AM
rattlerbob5.9's Avatar
That is an interesting concept
The compressor side of the turbo is up stream of the cylinder where the fuel is actually injected after the valves are closed and the air between the cylinder and the compressor is under positive pressure. So how does the fuel affect the cleanliness of the turbine blades ?????????????
I would be looking for a leak in the filtered air stream to the turbo, an over oiled filter, a bad oil seal or a large amount of play in the turbo shaft bearings allowing oil to get around the seal.
Mike L
Jul 2, 2010 10:06 AM
faylorz
Mar 13, 2010 07:39 PM
DNRCustoms
Off Road / 4x4
Feb 7, 2010 09:18 PM
barryp
Oct 25, 2007 06:07 PM
FastSS
Apr 15, 2006 11:53 PM
