Best lubricants
Best lubricants
I am sure this has been discussed many times, but what should I put in the 12 valve engine, trans, transfer, and diffs. Is synthetic best? New to diesels any help would be great. Thanks
My opinion of the best motor oils are 1- Mobil Delvac 1300 15 w 40, 2- Havoline URSA 15w40, 3- Shell Rotella 15w40. I generally use Wix filters. The 5 speed trans takes a synthetic oil and I usually stay with Dodge oil. I've read some posts that give alternate brands and better sources to buy it from. Maybe they will chime in for you. The axles can use either GL5 oil or synthetic. If you switch oils, make sure you remove the rear hubs and refill the bearing with fresh oil to avoid mixing. If you have a limited slip make sure you use limited slip oil and add the limited slip additive. Good luck
Howard
Howard
Stovetop535
30
Feb 12, 2008 06:21 AM
