band adjustment?
Old Oct 19, 2004 | 10:12 PM
gottahavediesel's Avatar
band adjustment?
are the bands in the auto trans on my 96 adjustable externally of the transmission or do i need to pull the pan which i need to do here shortly anyways and change my fluid out?
Old Oct 19, 2004 | 10:21 PM
RCW's Avatar
RCW
There are bands, and they are adjusted through the bottom after the pan is removed. Pick up a Haynes Manual # 30041 for about $15, and it will show you how this is done and provide the adjustment specifications. It is a real easy procedure.
Old Oct 20, 2004 | 09:36 AM
infidel's Avatar
Diesel tranny gurus I've talked to don't recommend routinely adjusting the bands, do it only if you are getting jerky 1st and reverse shifts. Getting the bands too tight will cause much more harm than good.
Old Nov 4, 2004 | 09:34 PM
bmoeller's Avatar
http://www.dodgeram.org/tech/transmi...T_band_adj.htm
Old Nov 20, 2004 | 11:52 PM
natloz2's Avatar
the bands are externally adjustable on your trans, but i agree with infidel, don't mess with them
Old Nov 21, 2004 | 05:57 AM
vtailflyer's Avatar
I adjusted mine last winter, From what I recall one is on the outside(drivers side) one on the inside of tranny after dropping pan.
I think the key of gettin a decent band adjustment is having an accurate, calibrated torque wrench. Without that, I would not touch them.
As I understand it, the bands are simmilar to rear drum brake shoes, and when the band material wears, they must be readjusted to get the proper tension on them when they engage. Kinda like adjusting the rear brakes.
Mine worked fine after I adjusted, but I have also heard of horror stories
Cheers
Old Nov 21, 2004 | 09:41 AM
CarlJensen's Avatar
One internal and one external adjustment. Torque wrench and experience required to do it per the book. Best if done by somebody with experience the first time and watch and learn.
Old Nov 21, 2004 | 11:23 AM
diesel_kid's Avatar
When I had dropped my Tranny Pan to change out the fluid and filter, I was going to adjust the bands per dodgeram.orgs instructions, but couldnt find the adjusting bolt they were talking about. I found one that looked like it but It didnt have a slot for a T40 Torx like I was supposed to use, it had nothing, so I just left them. Gonna check up on the haynes Manual and see.
Old Nov 21, 2004 | 06:29 PM
dalton4's Avatar
I agree with Infidel on band adjustments. My tranny has 147K miles and the bands have been adjusted once. This was done by Goerend at 73k when he had the tranny out for tc and vb mods.
Goerend is also not a big fan for adjusting bands just for the sake of doing it.
betsycam
Sep 26, 2004 03:44 AM
miketriton
Aug 20, 2004 01:14 PM
Outlaw02
Jul 8, 2004 10:16 PM
vtailflyer
Feb 1, 2004 06:43 PM
Dodgezilla
May 6, 2003 06:50 AM
