Bad blow by after valve springs
I'd sure check the turbo before fart'n with anything else. Let her run a few seconds before activating brake. They make fancy manometers for this but a bucket work too. Keep the end submerged
No i haven't tested the turbo, but it does sound like the culprit. Wondering if the rebuild kits on ebay for $80 or so are good parts? I don't have a extra turbo to rob the drain flange to make a spare
Not sure if it's proper but one thing that you can do is cut your oil return line along the part that runs at a 45* angle, towards the block. Cutting it at that spot will allow for you to slip a rubber hose on,and route to a bucket. Keep in mine that while the motor is running, your emptying the engine of oil.
Then add a second piece of hose to the return line.
You could also remove oil filter and try to slide a piece of hose on at the normal hose connection but the best I remember, its makes a very tight kink in the rubber and it won't gravity flow very well. I suppose you might be able to cut a inch or two, off the end of the tube and just use a longer piece of hose to replace the removed pipe.
How ever you do it, remove it from the motor before cutting, so no metal cutting's go on down the return.
As far as products off of internet, I have no clue. I buy my stuff from local places and never pay to much attention to the cost.
I'll bet someone else on this board has been down this road and maybe their is a good thread on turbo rebuilds and cost.
I never have to much luck with the search button,...anybody know a good thread?
this is a very interesting post. My poor old beast has close 400,000 on the stock turbo. I have been noticing alot of blow by, and just figured it was the miles and the abuse the truck has taken. But when i kill the truck, if i listen to the turbo spool down, it sounds rough, and kinda out of balance. Could i be on to something like a bad turbo bearing, or seals? There is not alot of oil comsumption, just leaks from the vacuum pump.
Check your shaft play, spin it by hand, is it free and smooth turning and look for any oil on the wheels or in the housing.
If it breaks and comes apart you could feed the engine with shrapnel and damage it as well
With those miles on it i would think it should be a wise investment in preventative maintenance to put a kit in it or have a professional rebuild on it if it is getting worn.
Also it would be a real pain and a big mess to try to clean out of the cooler.
I think it is safe to rule out the turbo. If the turbo seals were bad it would be leaking oil into the intercooler or the exhaust. It would not cause any significant blowby even with the exhaust brake on.
53 willys
23
05-19-2008 06:14 PM
12valve
03-11-2008 10:57 AM
GasganoFJ60
04-14-2007 10:36 AM
