Anyone lowered a 4x4??
Old Mar 19, 2006 | 11:11 AM
hotmopr's Avatar
I want my truck to sit like this truck. I would like 3" in the front and 5" in the rear. Anyone done it?
Old Mar 19, 2006 | 04:19 PM
infidel's Avatar
Those tires look sort of low profiled, bet it brings it down at least 3-4"
Old Mar 19, 2006 | 09:40 PM
Vaughn MacKenzie's Avatar
Unhappy
If you take a look under the front of your truck you'll see you're pretty limited how far you can drop it because of oil pan clearance.
Old Mar 19, 2006 | 10:24 PM
edge600's Avatar
A cheap way to do it is to heat the front springs and put shackles on the back. Ive done it before. Probably isnt the smartest way, but it works.
Old Mar 20, 2006 | 12:35 PM
gmctd's Avatar
Don't need shackles on the rear - just remove the 5" blocks, get the 2wd axle clamp u-bolts and you're down to 2wd oem level.
Or - shave the blocks to the drop you want, have the 4wd u-bolts re-threaded, cut off the extra length.
It's the front that will be the problem, because of required clearance for the third-member.
Jack the frame, remove the front springs, CAREFULLY lower the jacks till you get the desired heighth, then eyeball the available clearance.
Get the 2wd center-carrier bracket, 2"shorter than the 4wd item, for proper driveshaft angles.
Do whatcha gotta do.
Old Mar 20, 2006 | 12:43 PM
LanceD's Avatar
just pull the factory blocks and put some 1/2 ton coils on it
Old Mar 20, 2006 | 02:08 PM
Crimedog's Avatar
Lance D has her right there... it'd be a lot easier and cheaper
Old Mar 20, 2006 | 10:40 PM
cumminsdriver635's Avatar
What he said.
Eric
NO_SPRK
Nov 28, 2009 01:13 AM
kantdrive55
Jun 3, 2009 06:26 PM
V.R.Wheeler
Aug 4, 2007 01:00 PM
faster_than_ford
Jan 28, 2005 08:57 AM
