Adding tach to a 4BT....?
Old Jul 6, 2006 | 09:19 PM
JimmieD's Avatar
I want to add a tach to a 4Bt and that's about all I know about the project. Thinking it's about the same setup as a 6Bt 12 valve. What would I have to do to install a tach on this engine that never had one? Do-able? No computer installed. Thanks for any tips...
JimmieD
Old Jul 7, 2006 | 07:53 AM
JimmieD's Avatar
Okay, next question: what type of tach sender is used on the 6BT? Any links to info on 6BT tach and/or sender? Thanks....
Old Jul 7, 2006 | 08:45 PM
Tackett's Avatar
JimmieD
I just helped a friend put an AutoMeter tach on a Cummins/Chevy Suburban he built. It attaches to the alternator, and has an adjustment screw on the back.
We hooked it up, went for a drive and I adjusted the tach while we were moving. Pretty simple.
He got it from http://www.dakotaparts.com (they just changed their name and website, so you may need to call to place an order)
Old Jul 7, 2006 | 11:11 PM
bigwheels94's Avatar
You could buy a marine version.Get a VDO tach,& a tooth counter for the flywheel,& plug them in.That simple.There is allready a port for it in the bell hsng,@ about 11:00 looking from the rear of the engine.I think it's a 7/8 NC thread hole over the ring gear.You will need to know how manyteeth are on the ring gear also to get the right one.
Old Jul 7, 2006 | 11:45 PM
bgilbert's Avatar
Alternator tach or a tach that includes a magnet that glues to the crank. Just order the same thing you would order for a 6bt. Isspro makes both.
Old Jul 8, 2006 | 02:09 AM
JimmieD's Avatar
Thanks, guys, I really appreciate it! I guess I'm wanting my cake and to eat it too, as I hoped to install a complete & matching 'Vintage' type gauge set, either AutoMeter or S/W, but I may be out of luck on that one. The original dash has 3 3/8' [?] Speedo and Tach cutouts plus 4 more 2 1/16" holes, then I figured on adding matching Boost and Pyro down in the new console. May have to change that plan....but thanks for getting me going in the right direction!!
Old Jul 8, 2006 | 10:54 AM
bgilbert's Avatar
I have an Isspro 3 3/8" alt tach in my truck. You could get a matching 3 3/8" Isspro speedo and mount them in the dash. I have a pic in my photo gallery of the tach.
Old Jul 8, 2006 | 11:10 AM
JimmieD's Avatar
Thanks for the pics, and those gauges look really good. I may have to abandon my plan for deco vintage gauges to match my Town Wagon's 'nostalgic' look. Prices for all 8 [or 9] gauges needed are a little breathtaking.
Problem is I have a Mopar type Amp gauge and want volts instead, plus I wanted the boost and Pyro to match the other classic gauges. Also not sure using the GM fuel tank/sender if the Mopar fuel gauge will work. I guess a little more homework and a lot more cash flow is what I need. It's looking like about $500 just for gauges right now! Ouch....
JimmieD
Old Jul 8, 2006 | 12:35 PM
v8440's Avatar
Unless it's super light, I'd be leery of gluing a magnet on my balancer. In effect, you're adding an external weight and upsetting the factory balance job on the crankshaft. It might not matter with a small magnet at diesel rpm, but it's something to consider.
Old Jul 9, 2006 | 12:13 AM
JimmieD's Avatar
I appreciate your concern, V8440, but you're talking to a guy who ran a 360 with a 318 flywheel for several years. It was something like those beds they used to have in motel rooms where you stuck in quarters for the stimulating massage
When I did that swap I hdidn't know that one engine is internally balanced and one is externally balanced. At least you never fell asleep driving....
But seriously, thanks for the caution!
JimmieD
redneck_racer
Oct 17, 2007 11:42 AM
spunbearing
Aug 9, 2004 07:53 AM
mcinfantry
Jul 21, 2004 10:42 PM
driverswanted
Jul 8, 2004 10:22 PM
1340
Feb 12, 2004 11:26 AM
