97-3500 cummings
Old 09-16-2010, 01:21 PM
gnestrud's Avatar
97-3500 cummings
Code P0113 air Temp. sensor, where is it? truck starts when cool, or when I cool down drivers side of engine with a hose, cool down with water for about a minute and it starts fine, runs good, check codes with scanner and it threw the code P0113, seems like that might be the problem, any help ?
Old 09-16-2010, 03:55 PM
cmac's Avatar
the air temp sensor on my 98 12v is right on top of the intake just behind where the air comes into the intake. it has a small wiring harness plugged into it. two wires i think. here is a link to show you how you can test it. i got this from infidel: http://dodgeram.org/tech/dsl/trouble...niford_htr.htm
it is mostly about testing grid heater problems but there is a section on the air temp sensor.
p.s. there is no "g" in cummins
Old 09-17-2010, 07:01 AM
j-fox's Avatar
Keep that cold water AWAY from the injection pump.
gaylejoe
12-07-2010 08:25 PM
DieselMatt
24
07-18-2004 09:51 PM
sway825
01-12-2004 02:11 PM
98rammer
08-11-2003 12:46 PM
Hoss
02-25-2003 09:24 PM
Quick Reply: 97-3500 cummings
