-   12 Valve Engine and Drivetrain (https://www.dieseltruckresource.com/forums/12-valve-engine-drivetrain-100/)
-   -   '96 Loses power under load (https://www.dieseltruckresource.com/forums/12-valve-engine-drivetrain-100/96-loses-power-under-load-155872/)
TSB Jun 17, 2007 09:11 AM
I was towing a heavy trailer up a steep hill yesterday when the truck suddenly lost power and started to make a loud noise, almost like a huge boost leak or like you just blew a hose off your air compressor. On quick inspection I couldn't see anything visibly wrong and the truck would idle fine. I don'tknow what my EGT was at the time. When this occured I was at about 2200 rpm in second gear. I had to leave the trailer and go get my '05 which towed the trailer up the hill without a problem. My '96 will run fine now unless I give it more than about 1/2 throttle. If I go above 1/2 it starts making the noise, power dropps and I start to get alot of black smoke out the tail pipe.
I have towed heavier loads up steeper hills on many occasions with this truck and never had a problem. I don't let the truck lug down when pulling and I also don't hold it to the floor to get up the hill as fast as possible... Any ideas on where to look first?? Thanks!
xzaq103 Jun 17, 2007 09:48 AM
It sounds like a boost leak. Black smoke = less air. Im guessing you went to half throttle at idle? But at idle IM guessing its making enough boost to push air through a leaking boot. Have you check all of your boot elbows?
Chris
realtreehunter Jun 17, 2007 09:49 PM
sounds like one of your boots popped off put it back on and make sure all the others are on good and tight
1stGen545 Jun 17, 2007 11:26 PM
Mine did the same thing. I have had it happen to 2 others and it was always the lower boot on the I/C on the passenger side. They are not very tight from the factory. Check all of your boots and I'll bet thats what it is.
TSB Jun 19, 2007 07:21 PM
Thanks, it was the boot on the inlet side of the intercooler. I'm glad it wasn't anything major!!
Box5 Jun 19, 2007 07:30 PM
thats a good feeling to get that figured out i bet ^. now put the workhorse back to work, lol
