95 dodge cummins 12v takes awhile to start after sitting
my 95 dodge diesel after sitting for more then a day just started not starting unless i use gas pedal and once started it idles rough for about 30secs then it runs great like any other time. the engine is all stock except exhaust.
any help is appreciated.
kleinersforeigncar@gmail.com
Dido what Larry said and while your replacing the rubber return line you might want to look at all of the lines I did my return line and it fixed the problem but looking at the lines I will be back under the truck sooner than later!!
Yup change all rubber fuel lines and youll likely be good as new. Makes sure you use diesel rated fuel hose and not the gas rated stuff.
You can get it here:
http://www.fostertruck.com/dodge/
Replace them all the way to the tank.
My truck did the same thing. Started out doing it after pulling a load and then sitting overnight (pointed uphill). Then it started doing it whenever it was parked overnight pointing uphill,
Numerous users said to replace the lines. I had replaced the short rubber pieces many times but I went ahead and did the whole thing with marine diesel fuel lines. I didn't see any areas that looked bad but after the swap out I have not had an issue. It's not a walk in the park but neither is being stuck with your boat in the water.
Peter
Peter
that is exactly what mine did pulled a car on trailer and parked it overnight up hill. came out next day and must floor it and crank at same time which i am sure does not do the motor any good.
so tomorrow i will check the fuel lines out and go from there. this is my first dodge diesel so i am new at the dodges i specilize in vw tdi's.
thanks for all the help
Originally Posted by troy900ss
Same symptom but the fix was as simple as the fuel filter backing off/unscrewing and allowing air into the system.
Just wondering.
As I look back at my fuel line replacement I'm wondering if the problem wasn't with the fittings that attach to the tank and not the lines themselves.
The fittings were not tight on the barbs they are those funky push and clip types that can be very difficult to remove if you can't remember how. I didn't find a single place, in the lines that I removed, which looked even slightly bad. Over half of the length is steel.
Anyhow, if I had it to do again I would first consider re-doing the ends where they attach to the fuel tank.
Peter
Peter
When replacing the fuel lines removing the starter helps access. This is a good time to install LarryB's upgraded contacts. This is either do it now fix for $35 or replace the whole starter later.
The main problem on my 96' turned out to be the soft line from the fuel preheater to liftpump. The line had massive dryrot. It let lots of air into the system but no fuel would leak out.
baytownbrown
Nov 19, 2011 11:46 PM
05 CTD2500
Nov 5, 2009 01:47 PM
Pete Miller
Jul 19, 2005 09:13 PM
livewire
Oct 13, 2003 08:00 PM
