95 12v tc lu question
standard on/ off switch, push or toggle whatever flavor you like
http://www.tstproducts.com/Torque%20...p%20Switch.pdf
Just make sure if you use a lighted switch or indicator light that the switch has two sets of poles, STDP.
If you don't juice flows though the bulb filament and will mess up the lockup function.
I really want to be able to lock 2nd for windy steep mountain roads as I haul a 18,000 lb Hatachi EX60 up 18% grades to dig watering holes for wild game. My old duramax was able to shift locked but I here we don't want to let the 47 series makes its shifts while keeping the converter locked?
Also for 2nd gear lockup (manually selected 2nd gear) you need to pull apart the VB and block up a passage in there... google it, it works. I never had any catastrophic damage directly from shifting while locked up, but I wouldn't say it makes anything last any longer either.
edit: Here ya go adjustable hobbs switch, not sure on the range but can get with n/o or n/c contacts here.
03CumminZ4X4
02-01-2008 11:15 PM
Russell_d
02-25-2007 09:12 AM
CTD2001
02-03-2007 01:30 PM
