94 injectors ?
94 injectors ?
Need a couple new injectors for a work truck 94 auto with mild i think #6 tst fuel plate, stock injectors, can someone tell me the best place to get new or aftermarket ones reasonable shoud i replace all or just the bad ones ??? 202,000 miles on truck thank you ron
replace all 6 of them and www.tstproducts.com for the plate, and www.piersdiesel.com for the injectors, or www.vulcanperformance.com for injectors...ddp stage 1's or 2's should give you a nice gain in mpg's and a little power.
Bad news, pulled all 6 injectors out ,and had them checked and cleaned and they said they were all fine and that was not the problem,,, so i guess its the pump,,or worse yet the cyl,or valves ,,,is it possable to check the compression with the injectors out right now?? if so HOW?thanks Ron
I wouldn't even begin to think that your Injector pump was bad until I have checked everything possible. So what are the symtoms again? I lost my lift pump over the Winter on my 95 jsut came out of Nowhere! Have you replaced the overflow valve yet??
darrenG
Jun 21, 2005 10:24 PM
