94 broken down on interstate
#46
I have a lift pump coming. I am going to pull the old one tomorrow, pull and clean up/check the fuel heater, and replace the fuel lines to the tank, since I will have access to them.
#47
I am replacing the fuel line from and to the tank, I have deleted the fuel heater, I am replacing the 1/2" hose between the preheater and the lift pump, I am replacing the lift pump (waiting for it to come in), and the heater has a new screen in it. Any other suggestions, while I have things apart? The only thing left would be the pickup in the tank, I believe.
#48
That's on the agenda, just not yet. The lift pump came today, so I will put everything back together in the morning. If it isn't cleared up, then I will pull the bed and go for the tank; otherwise, I'll do that later. I don't have the bed off now- I was able to get my head and shoulders in between the frame and bed side, and change the lines. Not the most comfortable, but it worked and I was by myself/not in a position to pull the bed.
#51
The bad news- I've spent $399 on parts. The good news- I have a new fuel system, from outside of the tank to the injection pump. I know the fuel system real well, too. Back to the bad news- after installing a new lift pump, deleting the fuel heater, running new fuel line, and installing a new fuel filter, it still wouldn't run- I could barely get 15 pounds of pressure. So, I lifted the bed and pulled the pickup- it was a tablespoon amount of goop covering the inlet. The screen needed cleaning, but it wasn't blocked; the entire hole on the end of the pickup tube, though, was covered by this gray glob of stuff. I cleaned the whole unit, cleaned the screen, put it back together, and it runs like a champ now. It pulls about 22 pounds at idle, and about 38 running down the road.
Everything is working except for the temp gauge- I need to see if I knocked something loose, but let me ask this- I cut the wires for the fuel heater, and taped up the ends. I assumed that the could be dead ended, but do they have anything to do with the temperature gauge? I can't imagine that they would...
#52
My IP was sick...
#53
I don't know how the temp sensor plug got pulled off, but it did. I struggled for about 15 minutes trying to locate and reach it from the driver's side, then I tried over the valve cover- that wasn't too bad to reach.
#54
Instead of cutting the heater wires all you have to do is remove the heater relay located next to the shutdown relay on the firewall.
Hate to say it but I thought my truck was fixed after the dealer under warranty did most everything you did to your truck.
Six months later I had the same problem again...
Fuel pressure always remained great when it happened.
#55
It had been either removed or replaced before, because the wires were spliced and soldered.
Once I had the fuel pressure gauge, it was easy to see that a loss of fuel pressure preceeded the shutdown, every time. Which was a good thing- I had expected it to be difficult to observe the fuel pressure, since it seemed that a good bit of driving at highway speeds seemed to preceed my problems. But, the goo had really clogged things up, and I couldn't go 2 miles down the road before a shutdown. So, at least I didn't have to break down 50 miles from home to observe what it was doing.
It is running fantastic now.
#56
Your fuel delivery issue could be algea in the tank and lines. It is a black gooey mess.
Water and the right temps allow it to grow in the tank. Biocide is used to kill it.
(I've also used gasoline)
Take the line off of the lift pump and wrap a rag aroung an air hose and pressurize the tank to see it much fuel comes out.
Don't use more that 35 lbs of air.
I have seen this on one of my trucks.
I couldn't get any fuel at first!!! When I blew it back tot he tank and a higher pressure it popped and ran good after that. It was dosed heavy with biocide for several tanks, then we dropped the tank to check it. The sock was slimmy.
#57
I have the goo in a ziplock bag, sitting here on my desk. It is soft like silly putty, black, you can sqeeze it and it will ooze diesel, it pulls/stretches without tearing (to a point), and when you squeeze it, it flattens but stays together. It feels like silicone, impregnated with diesel fuel. I don't know what algae looks like in diesel fuel, but this isn't how I would imagine it.
http://s65.photobucket.com/user/br54...tml?sort=3&o=1
No doubt, the goo in the photo is what caused my grief. With a new lift pump, new screen, new filter, new fuel line/return line, new overflow valve, and deleted fuel heater, the truck still wouldn't run. I removed that quarter-sized blob, and it runs, it runs stronger than it ever has, and it hasn't stumbled at all. Before removing the goo, I couldn't go two miles without it quiting. Now, it is running perfect. And, it started easy this morning, with temps in the low 40's. It has never started that easy. Never, even plugged in. I am sure that is partly due to the new fuel system.
#58
Congrats on the solving of your problem. About 3 years ago I was experiencing similar conditions on my '97 and went through pretty much the same progression of fixes. A new lift pump solved the problem for me.
But now I am getting some stalling happening again and think I need to clean out the inlet in the tank. So what is the procedure to lifting off the bed?
I also have been w/o a fuel gauge since right after the warranty ran out and I would try a fix for that at the same time.
Also, how did you go about installing a fuel pressure gauge?
thanks,
Roy
thanks,
Roy
#59
thanks,
Roy
thanks,
Roy
