5th gear slack ?
New to the forum and finding some interesting info.
I have a 98 12v 5spd NV4500 with 108K on it. When running in 5th gear if I let off the gas pedal there is a obvious clunk. This also occurs when applying the gas pedal, but not as pronounced. No other gears have this symptom. Is this an indicator that the nut is backing off the 5th gear?! Thanks for the help sid |
If it dose it only in 5th gear, it is the nut for sure it just happened to my 98.5 two days ago. Soon you will look fpr 5th and noone will be home.The repair is easy takes about 3 hrs.Good luck on it.
Thanks, I'll get on it soon.
sid |
