-   12 Valve Engine and Drivetrain (https://www.dieseltruckresource.com/forums/12-valve-engine-drivetrain-100/)
-   -   5spd conversion questions? (https://www.dieseltruckresource.com/forums/12-valve-engine-drivetrain-100/5spd-conversion-questions-154087/)
Troutstrannysvc Jun 5, 2007 03:32 PM
I was wondering if anyone has cheap sources for the input gear for the T-Case, and also the pedel linkages/pedeal itself?
Also I remember somewhere on the web that a Ford clutch/flywheel will work on the NV4500, is this correct?
I put the clutch disk on the splines of my NV4500 and it lined right up, I'm just not sure about the flywheel?
Any information would be great!
Thanks
Box5 Jun 5, 2007 06:19 PM
I don't know if the ford flywheel will bolt to the cummins, but the 29 spline input shaft and bearing for the t-case I got through Rockland standard gear (search google for there website). It was the best price I could find, input shaft was $212, and the bearing was $38, you need both.
Pedals - ebay or the junkyard.
Troutstrannysvc Jun 5, 2007 10:10 PM
We deal through rockland gear I already priced through them I was just wondering if anyone had any cheaper sources.
Anyone else gonna chime in?
thanks for input
texastuff Jun 6, 2007 10:55 AM
The Ford flywheel is 10 bolt and the cummins is 8 bolt to Crank
Ram of Steel Jun 6, 2007 11:39 AM
This is where I get all of my T/case goodies. http://www.transfercases.com/
