4x4 Front bearing and hub question
Is it hard to separate what I would guess it's called the wheel spacer, extender, adapter? I took the 8 nuts off the studs from the bearing/ hub itself, and I gave up trying to get it off after a few hits with a dead blow. I didn't want to damage anything. It's the part that allows the dually wheels to be mounted, the 3/4 ton trucks don't have them. Are they pressed in or something? Or is mine just gonna be stubborn like everything else! Gahh!
I just did my u-joints and I think when I pulled the hub and bearings out, they got damaged. I'm getting a rough feel and drive from the front wheels, and the best I can describe it is a bad bearing feel and sound. It's most noticeable in low speed conditions. It's not real bad, they're not getting hot, even right off the highway they are still pretty cool. In fact you don't even notice it after 50mph. I lifted each wheel up and they move freely and don't make any noise. Kinda lost, hope I'm not making a mistake.
first time i took mine off is was violent with a bfh and block of wood. there not pressed on just get rusted up. i put some anti-sieze on the back when reinstalled and just took them back off yesterday to do swap and they just bout feel off when nuts were loose after three years in illinois weather.
GSP
06-30-2007 01:54 AM
Rob_OBX
02-21-2007 06:32 AM
