48RE parts into 47RH?
Old Sep 29, 2006 | 06:57 PM
Firstgenner's Avatar
Does anyone know what parts can be used from the 48RE to upgrade a 47RH for greater strength and durability? Things such as planetary sets, torrington bearings and clutch packs that will hold additional disks? I am sure someone has done this already somewhere out there. If so, would you be so kind as to list the parts required and where to purchase said parts?
Old Sep 29, 2006 | 07:13 PM
infidel's Avatar
I've always heard that a RH is stonger than a RE
Old Sep 29, 2006 | 08:18 PM
Racer9's Avatar
Actually, the 48 parts are much stronger than 47 parts.
In my research into a stronger trans, I found out all the 48re components fit into the 47re case, but the original type VB must be used. You can also just bolt in the 48re in and rewire the nuetral safety switch. On the '99 and older, (47RH) the original internal harness and GOV pressure sensor must be used.
Old Sep 29, 2006 | 09:32 PM
infidel's Avatar
Whoops, missed the 48 part, was thinking a 47re compared to a 47rh
Old Sep 30, 2006 | 12:57 PM
Racer9's Avatar
All the hard parts are the same. The only difference is that the re shifts when the computer tells it to, and the rh shifts when the tranny pressures tell it to.
nbaggett89
Dec 26, 2015 09:36 AM
freds40
Oct 22, 2011 03:26 PM
90firstgen
Dec 15, 2009 05:11 PM
schwzi
Sep 23, 2007 08:36 AM
CTD_Neil
Jul 19, 2005 08:13 PM
