46RH, 47RH differences
Old 07-15-2013, 02:01 PM
jonesy's Avatar
Hi all,
First an intro: I'm Ken, I live in south central Alaska. I have been following the Gen 1/2 forum for some time, learning what I could in anticipation of owning one. Now I have a 94 standard cab 4WD that I purchased last winter. I bought it with a trashed 47RH, and had a local shop rebuild it. It didn't get driven much during the winter; mostly I worked on the wore out suspension but that's another story.
The trans died within a couple hundred miles, and the rebuilder isn't standing by his work. I believe the case is defective, and the only replacement I have found so far is a 46RH case from a 92 diesel. My question for the transmission gurus is, can I marry the 92 case with the gear train, pump etc from my 94 47RH? Same question about the valve body. I don't know if the 92has a lockup converter or not, I have heard yes, and I have heard no.
It does have overdrive.
I won't bore you with the details of the troubleshooting and wrestling with the rebuilder that has convinced me that the case is bad. Long sad story.
thanks
Ken
Old 07-15-2013, 02:59 PM
dodgenstein's Avatar
92 does not have lockup. If the rear bands are the same, the cases are interchangeable. Not sure when they went to the wider band for low/reverse. I have a trans that came from a 92 truck (rebuilt by a nationally known reman co.)that has the later style case, so you never know till teardown what may be in there.
Old 07-16-2013, 01:12 AM
jonesy's Avatar
Thanks for the reply. Near as I can tell the lockup converter and the band change happened at the same time for the diesel trans, that being model year 1994. Someone please correct me if I am wrong. But like the man said, on the old iron, you don't know what you have until you take it apart and put an eyeball on it.
Jonesy
carsonc1974
03-09-2015 09:04 AM
speed75
07-11-2013 08:40 AM
Buckshotram
17
04-17-2006 02:45 AM
GO 4LO
06-10-2005 07:07 PM
Rammer64
04-10-2005 10:15 AM
Quick Reply: 46RH, 47RH differences
