4 wheel drive problem
Old Jan 31, 2011 | 05:23 PM
drake84's Avatar
hey guys i have a 95 cummins 12 valve 3500 single wheel autamatic trans when i try to put it into 4 wheel drive it feels like its geared to 4 wheel drive but the front tires wont engage i shift it to 4 low and it gears low but once again front tires dont engage any help would be great thankyou all very much
Old Jan 31, 2011 | 05:27 PM
patdaly's Avatar
Start at the CAD ( Center Axle Disconnect ) and see if you have Vacuum at the Actuator.
Old Jan 31, 2011 | 05:30 PM
drake84's Avatar
i checked that and there is no vacum there my vacum lines are real soft i dont know if that matters or not but no there is no vacum on either line what causes that thanks for responding
Old Jan 31, 2011 | 06:12 PM
patdaly's Avatar
Next, if your heater controls are switching properly from Defrost to vents, you know you have vacuum, it is a matter of tracking where the vacuum leak is or that the vacuum switch on the transfer case is not working. I would go to the switch on the TC and check for incoming vacuum first ( assuming your heater controls switch, they default to defrosters with no vacuum )
Old Feb 1, 2011 | 09:55 AM
blackimpala's Avatar
This might help.
http://www.dodgeram.org/tech/repair/..._engagment.htm
Floyd
Old Feb 1, 2011 | 12:36 PM
infidel's Avatar
Soft lines usually indicate that oil has got in the system. When this happens it can destroy all the lines, your vent control switch, vent control, 4wd vacuum switch, 4wd actuator, cruise control actuator and brake booster.
It is a very bad situation costing over $2000 to fix.
Luckily you might be eligible for recall, both my '95s were.
They will replace the entire vacuum system and give it a 7 year warranty for free.
With your VIN check for recalls here> http://www.dodge.com/webselfservice/...ilForm(%27R%27)
L.J.B.
Jun 27, 2014 10:21 AM
roxxx
Apr 13, 2009 05:15 PM
04ctd
Dec 7, 2007 08:19 PM
gman2310
Sep 27, 2006 12:08 AM
Teddy
Nov 2, 2002 01:56 AM
