3500 vs 2500 front brakes
Old Jul 8, 2011 | 11:01 AM
esde's Avatar
I am buying a rolling 3500 to swap the narrow dual wheel 80 rear under my 2500. I am also getting the front axle, but haven't seen it yet. Does the front use heavier brakes than my 8800 lb 2500 Dana 60? I always understood that your weight rating wasn't just how much you could pull, but how much you could stop. Anything to lose these craptastic single piston calipers. Also planning on running the 2500 springs w airbags instead of the 3500 springs, any thoughts on that?
Old Jul 8, 2011 | 11:35 AM
Purplezr2's Avatar
I thought the front brakes were the same and the rear springs were the same on the 2500(8800 gvw0 and the 3500, just the rear axle was narrower and rated for alittle more on the 3500 rear. Also you have a stock D70, so the 80 would be an upgrade.
Old Jul 8, 2011 | 03:32 PM
esde's Avatar
You're right, the 3500 has the same craptastic brakes. Looks like I'll rebuild the new one w ford knuckles and calipers while I regear both. Maybe an auburn carrier for the rear diff. Not sure what dodge was thinking w these shitty brakes. Even my dads f350 from 1980 had better front brakes.
Old Jul 8, 2011 | 03:51 PM
Tate's Avatar
If you're looking at doing the knuckles and then regear, you might be better off finding a HP60 with the desired gears and swap it in. Sell your dodge junk to recoup some losses.
Old Dec 23, 2011 | 09:12 AM
Mcmopar's Avatar
Does the ford knuckle swap make the front end wider?
Old Dec 23, 2011 | 11:48 AM
Tate's Avatar
AFAIK, its not the knuckles that make it wider, but the spindles. When I did my EMS conversion, my track became wider, about 3/4" on each side I'd say.
Old Dec 23, 2011 | 02:57 PM
Mcmopar's Avatar
Is it 3/4 for the Ford parts too?
Old Dec 23, 2011 | 03:29 PM
Tate's Avatar
EMS uses Ford parts. Stock Dodge knuckles, but Ford spindles. hubs, stub shafts, rotors, etc.
Old Dec 24, 2011 | 09:15 AM
blackimpala's Avatar
I did the Ford parts mod. Didn't measure the stock set up but not noticeable after the mod.
Floyd
Idaho Guy
16
Feb 12, 2020 11:15 AM
Dave Blakely
15
Nov 3, 2011 10:07 PM
dragginlx
15
Mar 9, 2007 11:32 AM
wildcargo
Nov 29, 2005 04:20 AM
xp8103
Mar 3, 2005 03:29 PM
