1st gen Cummins 9412v swap
So put a 94 engine in my 91.5 w250 and I used the first gen adapter plate because I知 running the 46re in my truck already. Now I知 having a issue where the flex plate is hitting the converter. Any ideas on what the issue could be!
The 46 RE...I am unsure what transmission this is.
I an familiar with the factory Cummins options of:
727, A-518 [some people call it the the 46 RH].
Then there are the 2nd gen Cummins auto transmission options of the 47 RH and the 47 RE
Are you using the same converter and flex plate as before? If so what could the problem be, as they are supposed to "hit" each other as they are bolted together.
92GhostRyder
09-16-2018 12:02 PM
SkyHarborCowboy
11-20-2012 08:58 PM
gator_grabber
10-01-2008 11:04 PM
