1995 12v injectors help!
I need a new set of injectors, I have a 1995 12v Cummins that was loved by a old man that kept up on everything, it has original injectors in it that have 270k on them! I want a set of injectors with a little more power, something that will make the truck a little quicker, I just don't know what kind I should get someone help quick!
Have you done any pump mods/tuning? Stock injectors are capable of almost double stock power.
FWIW my original injectors have over 270k on them and make good power, enough to peg 1600 pyrometer, outruns my 07 w/325hp too.
No I havent, but this may sound childish but I would like to have some smoke every now and then but I'm a little new to this diesel world, and I know about the fuel plate and I'm planning on removing it or grinding it, and I know how to do the star wheel, I would just rather do all that after I got an idea on what injectors I was putting in
What I think Gorms is trying to point out, there is LOTS off power to be had just tuning the pump.
Injectors might be un-necessary mod., and depending on what is picked it might just lead to a smokey mess.
I would start with cheap/ free pump mods before getting to injectors...
3k springs are a must, IMHO. Gauges, pyro and boost minimum. Then a fuel plate either removed or ground to whatever you like. Adjustable boost elbow to set the wastegate back to 30psi, or pinch the line off completely. Spend a little time researching how to tune the afc for your needs, and dial it in. That should be enough to slip a stock auto with 270k on it, may want to look into at least a shift kit and band adjustment if its an auto. If standard, stock clutch will be the weak link.
strokerace
13
Nov 15, 2007 06:52 PM
