180 pump max HP?
Ok...what is the highest recorded HP {diesel only} for a 180 auto pump...? ;)
Re:180 pump max HP?
more than 2..i think
Re:180 pump max HP?
I have the 180 pump with bigger injectors and a bigger camplate. I have dynoed as high as 390hp. I think I read that that was pushing it but I have no clue.<br>Aaron
Re:180 pump max HP?
I have seen :-X. But with some censored work you can get more. ;)
Re:180 pump max HP?
Cummnzpowr:<br><br>At the 2001 "Scheid Diesel Extravaganza" I hit 508 H.P.<br>on Scheids Mustang Dyno. My 96' Dodge CTD has the<br>180 pump which was "tuned" by Scheid Diesel. However,<br>I believe there has been a few other Dodge CTD's with<br>the "180 pumps" that have higher H.P. #'s than me now.<br><br>You can reference this website to see the results of<br>the 2001 Dyno numbers: www.scheiddiesel.com.<br>(Click on "Events, 2001 Diesel Extravaganza")<br><br>--------<br>John_P
Re:180 pump max HP?
Sleddy has a highly modified 180 pump and did 557HP.<br><br>Don~<br><br>
Re:180 pump max HP?
Call Dan Scheid and ask him what those pumps can put out!!
Re:180 pump max HP?
Why would you modify a 180hp pump when you could trade it off and buy a 215 pump. They are the better ones right?<br>
Re:180 pump max HP?
Didnt 95 with the 5 speed come with the 215 hp pump? if not, which truck(s) did?
Re:180 pump max HP?
Ok let me add something here, what is the highest H.P. with 12MM plungers and barrels. <br><br>Jim
Re:180 pump max HP?
[quote author=Mack Miller link=board=16;threadid=8121;start=0#78811 date=1039583236]<br>Didnt 95 with the 5 speed come with the 215 hp pump? if not, which truck(s) did?<br>[/quote]<br><br>The 95 5-speed has a 175 pump. the 96-98 5-speeds have the 215 pump.
Re:180 pump max HP?
[quote author=Jim Fulmer link=board=16;threadid=8121;start=0#78857 date=1039610386]<br>Ok let me add something here, what is the highest H.P. with 12MM plungers and barrels. <br><br>Jim<br>[/quote]<br><br>Measured and verified by dyno runs on diesel fuel only is Joes truck at 633HP. All the Cummins Dodge pumps that are the P version have 12mm P And B assemblies.<br><br>Don~
Re:180 pump max HP?
[quote author=Don M link=board=16;threadid=8121;start=0#78913 date=1039620707]<br><br>All the Cummins Dodge pumps that are the P version have 12mm P And B assemblies.<br><br>Don~<br>[/quote]<br><br>Not all of them Don.<br><br>J.R.
Re:180 pump max HP?
Oh really...which Dodge Cummins pumps have smaller or larger P&B assemblies?<br><br>Don~<br><br>
Re:180 pump max HP?
The ones that have been reworked with 13 and 14mm :o plungers and barrells. Yes there are a few out there. And they are on street driven trucks. They did not come stock tho. Moddified by Columbus diesel and Scheid Diesel. Yes Don you are right about the stock pumps tho. ;D<br><br><br>J.R.
| All times are GMT -5. The time now is 05:47 AM. |
