12V tranny shift wierd//Upgrade questions for Newbie
Old Mar 16, 2006 | 08:57 PM
jeeptjstud's Avatar
My dad has a 96 12V and when he is pulling a trailer in drive, the transmission will want to shift down too far if you press on the gas too hard. Any ideas on the problem? Also---He wants to add some power upgrades to it. He asked me and all I had to say is, I dont have any idea about the 12V, Im a 24V man! He wants to spend around $800 for upgrades.
Any input will be greatly appreciated.
Old Mar 17, 2006 | 06:32 PM
Willy91's Avatar
I'm not sure about the tranny but for horsepower upgrades a #10 plate would probably be a good plate if he pulls alot. Depending on how much more power he wants he could also install a set of 370's. Then if he had EGT problems while towing he could install a valet switch. Also either a three or four Gsk(Govener Spring Kit) would help alot.
Old Mar 17, 2006 | 08:03 PM
big jimmy's Avatar
Try locking out OD - that will put it in 3rd with the TC locked up. Then when he does not need to go heavy on the throttle he can go back into OD.
Old Mar 18, 2006 | 11:10 AM
infidel's Avatar
The TPS might be too sensitive and need adjustment or replacement
Instructions: http://dodgeram.org/tech/transmissio...TPS_adjust.htm
Dave7060
0
Feb 13, 2012 05:03 PM
scjfly
May 19, 2010 08:50 PM
thrashingcows
Apr 13, 2010 07:05 PM
dieselrob
Oct 12, 2005 02:21 PM
drecu
Aug 19, 2003 12:17 AM
