12 Valve Losing Fuel Pressure
I have a 94 12 valve auto. From idle to 2000 it maintains a steady 20 psi fuel pressure, but as soon as it hits 2000 rpms, the pressure starts dropping. Anybody have any input on this? I haven't started troubleshooting this yet. Just wondering if anyone has had the same problem so I'd know the best place to start.
There are three normal causes of low fuel pressure on a 12V. The first thing to check is to make sure that your fuel filter(both the prefilter and cannister filter) isn't clogged. Another is the lift pump which only rarely dies. The other is that the overflow valve isn't working right. To check the overflow valve, try pinching off the fuel return line some and seeing whether the pressure stays up. If so, the valve is bad. If it isn't the overflow valve and it isn't the filter, it is probably the lift pump. In rare cases, there can be a bad enough air leak that it causes these symptoms but you usually will have serious starting issues first.
krawler-N-tow
21
08-17-2011 08:14 PM
twoscooterz
03-12-2008 11:38 PM
ASTAR
07-06-2006 09:25 AM
Booost Almighty
03-01-2006 10:22 AM
