tach not reading right
Old Aug 12, 2012 | 08:19 PM
Timmer's Avatar
hey all- my tach on this truck is showing a 500 RPM idle. it jumps from 800 to 1100 tho as i rev up the motor....
any known problems with this?
Old Aug 12, 2012 | 09:00 PM
06dodge4x4's Avatar
It is a common issue from what I can see. My tach reads 0 most of the time. Occasionally it will jump up to 5000! It even spent some time stuck clear at the peg.
Old Aug 13, 2012 | 04:07 AM
FastTaco's Avatar
Mine reads around 400 at idle and seems to get close while driving. Any fix or recall for this?
Old Sep 17, 2012 | 12:23 PM
Timmer's Avatar
hello? new gauge cluster?
Old Sep 17, 2012 | 06:04 PM
55_Cans's Avatar
Go to the www.cumminsforum.com and search "06 tach issues"
Scroll down and look for the thread called "06 tach issues" The third page gives a fix procedure you can try before you shell out $350 for a new cluster. Lots of people tried it and were successful, I did and wasn't. It's worth a try.
Old Sep 17, 2012 | 08:53 PM
rockcrawler304's Avatar
Ok, with regards to the TACH issues I have a 2006 dodge ram, just bought it and I had the problem that many of you have. And paying over $100.00 closer to 200 is total crap for a 10 min fix. So here is the fix that worked for me.
1.) remove the gage cluster from the vehicle
2.) remove the screws on the back side of the cluster staring with the screws on the tach side. You will notice the circuit board will flex up about a 1/16 to 1/8 of an inch as you continue to remove the screws working from the tach side across.
3.) there are a number of IC's you should now see when you remove the black plastic cover.
4.) if you divide the cluster in half and focus on the Tach Side there is four large IC's (talking very basic so everyone can understand). One that has leads comming out of all four sides and three that only have leads comming out of the two long sides.
5.) now this will test your skills at soldering. you need to apply flux (a Flux pen works good)to leads of the IC's and reflow (resolder) all the leads.
6.) When you put it back together I suggest to shim the board on the Tach side so the screws do not pull down on the board when you tighten down the screws.
And a link to his pictures
http://www.keepandshare.com/doc/3998...m-2-8-meg?da=y
To save a bit of time searching.
I think I will try this soon and will also do a writeup with pictures and hopefully it works!
Old Sep 18, 2012 | 12:58 PM
Timmer's Avatar
thanks guys, ill look at that.
mullishacrew
Mar 18, 2012 12:41 PM
Erik@LCD
Jun 16, 2008 07:05 AM
rock crawler
Apr 4, 2008 03:37 PM
Dinner
Dec 25, 2007 12:09 PM
scoutman
Nov 30, 2007 02:56 PM
