Is this safe?
Old 03-10-2017, 11:25 AM
junebug95628's Avatar
Is this safe?
I'm looking for opinions on the safety on this setup. Just because it looks unorthodox doesn't mean it's unsafe so please excuse the appearance. The trailer is a 21' cuddy boat, I'd imagine ~8k lbs. Please include a quick statement on your opinion.
P.S This is not my setup but a friends where I'm trying to backup my position from people who are smarter then me
Old 03-10-2017, 12:30 PM
deere country's Avatar
I wouldn't use that to tow anything, not even across the street.
The following 2 users liked this post by deere country:
mknittle (03-11-2017), Russ Roth (03-11-2017)
Old 03-10-2017, 01:23 PM
Busboy's Avatar
Sorry I'm lost for words on this one.
The following 2 users liked this post by Busboy:
Old 03-11-2017, 01:15 AM
1320Fastback's Avatar
As a Californian please let me know when he will be towing so I can make sure and stay off the roads that day, thank you.
The following 2 users liked this post by 1320Fastback:
Old 03-11-2017, 09:44 AM
Admin Team Leader
Lary Ellis (Top)'s Avatar
Like the others here I would not wish to be on the same road as that mess.
The following 2 users liked this post by Lary Ellis (Top):
Old 03-11-2017, 10:55 AM
Received 2,378 Likes on 1,572 Posts
A would guess any DOT guy would have a field day if they saw that on the road.
Old 03-11-2017, 01:21 PM
mknittle's Avatar
just when you think you have seen everything.
Old 03-12-2017, 09:19 AM
gorms's Avatar
That's pretty rough. Would like to have the break-away cable attached to the truck rather than extension number 2, at least.
Then again those bicycle lock cables are probably overkill....
Old 03-12-2017, 09:37 AM
saggonwaggon91's Avatar
Safety chains not attached to the tow vehicle frame, break-a-way cable not attatched to the tow vehicle frame, use of ratchet straps, appears to be g43 chain(should at least be g70), Chain conection point at the outer edge should be at the bottom as to not strain the small amount of weld on the chain link. Not much different than the setup of the older tow trucks however, I would not use this setup on the road due to safety and liability, off road use only.
And it just looks plain hilljack.....
Old 03-12-2017, 03:25 PM
Busboy's Avatar
All else aside that looks to be surge brake controller on the trailer and only wire for the lights so probably a boat trailer. Without a solid/rigid connection the trailer brakes might not work properly.
Old 03-13-2017, 11:00 AM
Thanks for the input gals and guys! Hopefully, this will convince him to rethink this mess.
Old 03-13-2017, 06:39 PM
SOhappy's Avatar
Just checked the calendar. Nope, not April 1st yet.
Old 03-19-2017, 01:09 PM
Harvie's Avatar
I think it is missing just a few bungy cords.
Old 03-19-2017, 01:27 PM
KATOOM's Avatar
In your buddies defense (because it sounds like he's going to need it), there are similar type arrangements for receiver extensions used with in-bed campers in order to reach out far enough for towing. That said, lots of people dont like to use those either.....
But this disaster in the picture is either a joke or he's truly not understanding the leverages and forces at play here.
Diesel Dave
07-09-2003 06:54 AM
popeye
06-24-2003 11:11 AM
BEHRMAN
04-03-2003 05:02 PM
AKDSLDOG
03-14-2003 10:17 PM
AlpineRAM
12-22-2002 09:04 AM
Quick Reply: Is this safe?
