s400 VGT????
s400 VGT????
well i came across this the other day, been dreaming of one for the last year, and ended up getting it for free, what do you think it will do on my 98 inplace of the s475. this one also is a 75mm comp wheel, i found a mechanical actuator to use, but might just tie it shut for now to see what it does
The Guru
Have you taken apart the turbine housing and see what the vanes look like. It should help with the positioning of the actuvator. Looks like a easy turbo mod. How big is the turbine housing? It looks bigger than the typical S475 turbo.
Sixpack73
15
07-17-2009 07:31 PM
