Loosing boost under full throttle
Old 07-04-2015, 03:18 PM
wyattearp29's Avatar
My truck is loosing boost under full throttle. when i get in it it builds boost to about 25psi and then Drops. My truck then blows all kinds off black smoke. I did a boost leak test and all of my boots are good. I am thinking maybe a bad waistgate.
Old 07-04-2015, 04:00 PM
Dieselbuilder's Avatar
Sounds more like your air cleaner is plugged?
Old 07-04-2015, 08:33 PM
So, maybe it is sucking it flat
Old 07-05-2015, 04:53 PM
SIXSLUG's Avatar
What mods do you have?
You might just be maxed out on a stock turbo...
Old 07-05-2015, 09:39 PM
gorms's Avatar
How is your 351cw set up? Spring gate or?
Old 07-20-2015, 11:46 PM
KATOOM's Avatar
Without knowing the setup, it sounds like the wastegate is releasing boost.
Old 09-10-2015, 09:09 PM
Rockyhud's Avatar
When I've experienced this problem (boost goes up and then drops to about 20 psi) I've always found it to be a fuel filter that's clogged up with whatever. A fuel starved engine can't make boost like it normally does. I'll first try bleeding any water in the fuel filter canister and see if that cures it but usually it requires a filter change to fix the problem. After replacing the filter (and getting the truck started and any air in the lines purged) I can take it out and punch it and it holds a solid 29-30 psi boost (good for tune level and my elevation of nearly 7000 ft). Just looking at the old filter won't necessarily indicate it's blocking fuel flow, but once the new filter is in place you'll feel the difference.
Old 10-18-2015, 10:33 PM
totalloser's Avatar
I read that again, deleted my bad info. I thought fuel delivery too, but rolling coal when the boost drops sorta disputes that.
Kinda sounds like symptoms of a soft connection boost leak. As in pipe boots. Sometimes they sound like a cat in the belts, but sometimes not.
I doubt the WG, since by design their performance doesn't fluctuate much. Even with dramatic failures I wouldn't expect fluctuations.
Onemoparnut
08-19-2013 08:11 PM
kldeep
0
06-16-2010 02:21 PM
Mallard
04-09-2007 12:59 AM
j
11-14-2003 09:38 PM
memphisaudio
10-11-2003 01:00 AM
Quick Reply: Loosing boost under full throttle
