Holy Moly!
Holy Moly!
well for them that plan on keeping there trucks a while I thought I would show you what happens to the old mighty Cummins . lock tight them gear case bolts or it can cost you big $$$$
this is the third time I have seen this now.sounded like a super charger as it was getting eat up by the cam gear.
He drove over to my friends to ask who works on his trucks and I heard it, and told him don't even think about re starting it we pushed it in the drive and bingo .I had a feeling that's what it was .its a real sickening sound. just started doing it
Going into mine today as I have to replace v.p thought this would be as good a time as any..... I've had some strange noises cumm'in from top /front of engine..... I think this is going to be what I'll find. It doesn't do it all the time And no major oil leaks yet/ cracked case. Nate
The killer dowel pin and theese bolts are located under the black timming cover on the front of the engine. The dowel pin actually holds the whole timing case in position but the dowel can come loose and get into the gears and usually takes out the timming cover, this is why its called the killer dowel pin. The bolts are the ones that hold the timming case to the block. They can destroy the case too.
