gauge help please
gauge help please
Greetings All,
I’ve just purchased a 2001 Ram 2500 4x4 and am new to diesels. I’ve always wanted one, but my 318 4x4 just would not die. It’s still going strong, but the body is like Swiss cheese. So I talked the Boss into the 2001.
Now, I've been doing some research on gauge packages on the net and it’s pretty standard to have an exhaust temp, transmission temp and boost gauge along with the pillar mount to complete the purchase. My truck is a stock 2500 right now, but I’m looking at a Bully Dog Rapid Flow Induction air intake system and a Torque Dog on my desk here. I plugged a brick into my truck and got a P0216 code. (Injection Timing Control Circuit Malfunction) The lift pump was replaced before I bought the truck and it looks like a stock replacement. With the P0216 code, it's making me think that I need a fuel pressure gauge. Reading previous posts, I getting that the fuel pressure gauge is a must have, so which gauge do I replace in the kit, transmission temp? Also, what scale should I order for these gauges?
Help Tim spend some more money!
Thanks, Tim
Thanks, Tim
I would look into a Edge Juice w/attitude or Quad Adrenaline w/pulse. Both have a display that monitors all of what you listed and can cut power and give audible alarms for too high/low values so you dont have to stare @ the gauges. They also have a power benefit of at least timing and can tap the pump wire for up to 140hp on the juice and 180hp w/ADR.
The 216 code by itself isnt a death sentence and may never come back. but YES a fuel pressure gauge is a MINIMUM for the VP trucks.
By the way, Welcome to diesels!
P0216 means its far too late for a fuel pressure guage. You need an injection pump.
If you are going to tow, you need still need the tranny temp guage. So youre looking at Pryo, boost, tranny temp and fuel pressure.
How do I know if the injection pump is pooched? My truck runs very strong, and am getting a little over 600 miles to the tank. Right now I think the pump is doing it's job.
Other nice feature of the digitals is a "chime" for high/low readings, so you dont have to stare at them to know when there is a problem. Also have protections built in to keep EGTs or max boost or min fuel psi, whatever you want. No gauge does that.
Put a OBDII scanner on the truck - note code, clear them and see if they come back. If the pump is dead youll soon have hard starts when warm, dead pedal, white smoke or be walking to work.
QWKRTNU
10-24-2006 08:23 AM
MoparRiggan
01-17-2006 12:43 PM
